SysAid Agent Settings with Jamf Pro
  • 10 February 2023
  • 66 views
Has anyone had any success with deploying the SysAid Agent for Mac and having a configuration file that populates with URL, Serial and account? We use Jamf Pro to push out apps and configurations for our macs and I can get the package to install, but it doesn’t fill in the above information.
We do not use the RDS for Mac.
Thanks!
Hi @GHowe ,
It is possible when using Network discovery and RDS unfortunately not sure about Jamf but if this is important to you please add an idea and let’s open it for voting!
So your options from SysAid are:
Manual Agent deployment or Network discovery
Also we had this workshop in septemebr about all the nitty gritty of asset management that you might find interesting:
