Renew SSL Cert
  • 27 April 2023
  • 90 views
Hi, I’ve updated the path with the new cert name on server.xml file on the app server.
Restart the SysAid server service and it still shows the old cert.
What else should I do?
Userlevel 3
Hi @OfirMY
Please send us your serverConf.xml file which is located in this path: ...SysAidServer\root\web-inf\conf
If you wish, you can also contact Support for further guidance.
