Filter "Phase"
  • July 5, 2023
  • 92 views
I would like to set-up view to be able to filter (see) all requests in selected phase of workflow.
I can’t find field Phase in Sysaid.
BR, Irena
Best answer by alin.lupascu
Hi @irenazajc,
I’ve put together a video in attempt to assist with this query. Have a look and let me know if it does help and if you have any questions.
https://sysaid.zoom.us/rec/share/0S7PecEjiG2TERDZJLC6CdOXels1_Bgdtd21hvQ8Ot6ILCkoHqgI0kz5lco2II8.EzBwlftVT9CKgcGP?startTime=1689935403000
Passcode: N6=huSHT
Static filter in the video: r.status=0 and sub_tab_order!=0
Note!
  1. Make sure you first copy it into a notepad and make sure there are no spaces at the beginning nor the end.
  2. Do not save the static filter Under “DEFAULT” instead create a new view.
iulian.olaru
Please check our guide on customizing views and apply it to your specific case:
https://documentation.sysaid.com/docs/customize-lists
alin.lupascu
  • July 21, 2023
Hi @irenazajc,
Passcode: N6=huSHT
Note!
