Hello Everybody!
We are trying to do a massive import of items to our CMDB, but I find this problems;
Error in line 1 (or 2,3,...)= -1
If I have a CSV file with multiple CI from the same Type, has all the fields be completed?
I mean, in a list of 20 laptops, some has "Assignament Date" but not others...
Is necessary to all CI has the same completed fields?
Where can I check a Log about this?
Many Thanks.
I ran into this issue too.
I ended up dividing my import file into 2 files, one with a date in the date field and one without. I couldn’t get it to work with them combined.
Good luck!
