Hi SysMates,
Ziarot (aka Z) here from the customer success team, had a conversation with the awesome
So… when a ticket is closed and the auto notification is sent out you can add a satisfaction survey to help you track your team's activity and identify learning moments. Adding emojis to your survey is a quick and intuitive way to get your end-users to reply and share a bit more.
So the steps to add emojis are quick and simple:
- If you don’t have a question ready you will need to create a survey question:
Go to: Settings > Customize > Service Request Survey > Create New > populate the fields marked in the screenshot and don’t forget to hit OK!
- Add “if statement” for status SR closed tickets in the email notification, Go to:
Settings > Customize > Notifications > Edit Notification #5 (default request user notification)
here is an example of the syntax needed:
#elseif( ${Status}=="Closed" ) Your service request #${ID} has been closed. We hope that you are satisfied with the service provided to you.
#end
- Follow these steps to Insert an emoji survey
*if you already have a survey link implemented you will need to remove it and add the emoji survey instead.
Let see how it will look from the request user side:
In the body of the email:
Once they click on a smiley it will open a new browser window:
Request user can then add free text or simply click Submit to share the emoji ranking.
Note: Their reply will only be recorded once they hit submit
Then request user receive a confirmation on the submission in the browser window:
Examples of commonly used survey questions:
- How would you rate the quality of the service you received for this service record?
- What did you think about the service you received?
What do you have at your organization? share with us in the replies!
Suggested ranking:
1 Poor | 2 Fair | 3 Good | 4 Very Good | 5 Excellent
That’s IT, let us know how it goes for you,
