Change management workflow
  • November 6, 2025
  • 47 views
Please, we’ve implemented a change management process.
I’d like to know how we can track post-production follow-ups with their respective timelines directly within the same change ticket.
## Track Post‑Production Follow‑ups (within the same Change)
You can manage all post-production activities and their timelines inside the original Change using a combination of workflow tabs/action items, tasks, activities, and reminders. Here are practical options—pick one or combine as needed:
### Option 1: Add a “Post‑Implementation” workflow tab
- Use Workflow Designer to add a tab after “Implement/Review” (e.g., “Post‑Prod Monitoring,” “Hypercare,” or “Follow‑ups”).
- Add action items for each follow‑up (e.g., “Validate KPIs at +24h,” “User feedback review at +72h,” “Stability sign‑off at +7d”).
- Assign each action item to the responsible admin/group, set due dates (timelines), and enable notifications.
- Benefits: Clear gated process, due dates per action item, SLA/overdue highlighting on the tab.
How:
- Go to Settings > Service Desk > Change Templates > open your template.
- Open Workflow Designer.
- Insert a new tab after your “Implement/Review.”
- Add action items (process or approval), set “Assigned to,” “Due date,” and “Notification ID.”
- Save template; future changes using this template will include the new tab.
### Option 2: Use Tasks (child items) with dates
- From the Change, add Tasks for each follow‑up checkpoint (you can create a “Post‑Prod Follow‑up” task template).
- Set Start/Due dates per task and assign owners.
- Benefits: Granular tracking and Gantt-like visibility in task lists.
How:
- In the Change record, click “Tasks” > New Task (or from template).
- Name tasks with the time marker (e.g., “Post‑prod KPI check – T+24h”).
- Set due dates and assignees; enable task notifications.
### Option 3: Log Activities with reminders
- Add Activities for scheduled checkpoints and include: date/time, outcome, and next steps.
- Create reminders/escalation rules to notify the owner before the planned checkpoint.
- Benefits: Lightweight for simple follow‑ups.
How:
- In the Change, click “Activities” > New Activity, set “Planned Start/End.”
- Use Settings > Service Desk > Escalation Rules to send reminders X hours/days before the Activity due.
### Option 4: Post‑Implementation Review (PIR) form
- Add a custom “PIR” form (fields) on a dedicated workflow tab to capture outcomes (KPIs, incidents post‑go‑live, rollback notes).
- Include an Approval action item for final sign‑off after monitoring period expires.
How:
- In the template’s Form Designer for that tab, add custom fields (e.g., “Issues observed,” “MTBF,” “User satisfaction,” “Rollback needed?”).
- Add an Approval action item “PIR Sign‑off” with due date = go‑live + N days.
### Timelines and automation tips
- Due dates: Use relative dates in templates (e.g., Implement completion date + 1 day) if you maintain those via a small rule or set them manually upon completion of Implement.
- Notifications: In each action item’s Attributes, set a Notification ID that includes reminders and embedded actions if approvers are end users.
- Escalation: Create rules to alert when follow‑ups are overdue.
- Calendar: Activities and due dates will appear on admins’ calendars; PSOs can also be posted as Activities if useful.
- Visibility: Keep the “Change Details” tab read‑only post‑go‑live and make only the Post‑Implementation tab editable for follow‑up owners.
Would you like me to walk you through adding a “Post‑Implementation” tab to your existing template and suggest default action items (T+24h, T+72h, T+7d), with fields and notifications? If you share your current template name and which checkpoints you need, I’ll tailor the steps.
I wanted to follow up to see if you need any further assistance with setting up tracking in your Change Management process.
As an additional tip, outgoing and incoming emails can be tracked using the Messages field, which you can add to non-workflow tabs through the Form Designer.
Within action items, you can also add a Notes field for updates or include Date/Time fields to help track follow-up milestones more precisely.
Provide more details about what you would like to achieve in case further assistance is needed.
Please also confirm your environments Account ID.
