How can I enable integration with Azure DevOps?
How can I enable integration with Visual Studio Team Foundation Server (Azure DevOps)?
I am very curious on how to do this also. We understand you can do this with Trello but can this be accomplished with Azure DevOps? Any information would be greatly appreciated.
JeffReed
Hi JeffReed, maiconpereria,
ICYMI Azure at SysAid Marketplace now support multi-tenant!
Keep crushing IT,
The link is AD azure not Azure Dev ops, is sysaid getting Azure Dev Ops integration anytime soon?
An Azure DevOps integration is available using Zapier from Marketplace (if the question is still open).
