Escalation Rule effectiveness
  • 14 October 2022
  • 35 views
I have created an rule that should trigger the action (send notification) 1 hour after the SR is created and unassigned. When an escalation rule is created or updated, does the rule affect:
  1. Tickets created after the rule was updated/created?
  2. To all existing tickets?
Cheers
Hi @SChandiramani
If the ticket meets the criteria set by the escalation rule then it will be applied no matter if ticket was created before the escalation rule or after.
