Update CI relations - Assets to CMDB
  • 28 September 2022
  • 58 views
Please share any information you have on the “Update CI relations” function under Settings> CMDB> Import System Items.
What exactly is updated?
Does it look at the software on a laptop and connect it with the software product in the CMDB?
Is this update run automatically, like the Asset Import/Delete function, or does it have to be run manually?
Thanks for any information you can provide.
Heidi
Also, I would guess that it only does an import as opposed to synchronizing the information.  Can you confirm?
Hi @HeidiCF,
Check out the scheme here it maps out updates and relationships for this. Schedule wise this can be initiated only manually.
