hi, I have a group of agents. I need that each agent only view his own tickets. Where can I define it? I try in the permissions in the agent group but it is not working. Thank you
Hi
Select both View service records.. and Create/Modify… to “Admins and Groups only.
The next step is to navigate to Tools → Administrators → Select the ones that need to inherit groups permissions → Apply Group Permissions.
Hi Alin, thank you, It’s working perfect!!!
