Two years ago, Microsoft announced that it will no longer support basic authentication protocols (SMTP, IMAP, POP). The time has come when you need to move to a more secure and updated protocol - OAuth 2.0.
Setup of the new email integration is simple:
In SysAid, go to: Settings > Integration > Email.
Click the Create New button, and follow the instructions in this Microsoft 365 Email Integration with OAuth 2.0 Guide. The permissions required on MS side:
Test and verify the new integration: Send manual email, reply from tickets and take actions that trigger automatic notification.
To disable the SMTP integration [see screenshot below]:
In SysAid, go to: Settings > Integration [1] > Email [2].
Choose the SMTP integration list item and uncheck:
Select the Outgoing Email tab [3]
Uncheck Enable outgoing email
Click Apply [5].
Select the Incoming Email tab [4]
Uncheck Enable incoming email
Click Apply [5].
A few important notes:
This update is relevant for cloud and On-premises accounts.
For On-premises, Microsoft 365 Exchange OAuth 2.0 is supported from version 20.4.74 and up.
There is a workaround available to provide you with a short time extension if needed, read more about it here.
If you have any questions please ask away in the comments!
Regards,
