Can you tell me where I can download the files for upgrade my SysAid on prem.
Regards.
Best answer by iulian.olaru
View originalHello,
Regards.
View originalHi,
Here you can find the direct SysAidServer Upgrade Patches Links (64-bit):
v23.3.34:
v23.2.14
v22.4.45
v22.3.35
v20.2.14:
v20.1.14:
https://dp3qdkv6ibrud.cloudfront.net/OnPremUpgrade/20.1.14/SysAidServerPatch64_20_1_14.exe
Here are the Upgrade Release Versions and Compatible Versions. Use this to determine your upgrade path. Important: Make sure you backup your database before initiating a version upgrade.
Release | Date | Compatible Versions |
SysAid 23.3 | September 28, 2023 | 22.4 and above* |
SysAid 23.2 | July 3, 2023 | 22.3 and above* |
SysAid 22.4 | February 7, 2023 | 22.1 and above* |
SysAid 22.3 | December 7, 2022 | 21.4 and above* |
SysAid 22.1 | June 6, 2022 | 21.2 and above* |
SysAid 21.4 | January 31, 2022 | 20.4 and above* |
SysAid 21.2 | September 8, 2021 | 20.3 and above* |
SysAid 20.4 | March 8, 2021 | 20.2 and above* |
SysAid 20.3 | November 12, 2020 | 20.1 and above* |
SysAid 20.2 | June 28, 2020 | 19.4 and above* |
SysAid 20.1 | February 24, 2020 | 18.1 and above* |
Excelent. Thank you very much iulian olaru
