Our malware scanner detected malware in your software that we want to bring to your attention in help of a resolution:
- Filename: /public_html/support/inc/common.inc.php
- File Type: Not a core, theme, or plugin file from wordpress.org.
- Details: This file appears to be installed or modified by a hacker to perform malicious activity. If you know about this file you can choose to ignore it to exclude it from future scans. The matched text in this file is: $id = $id[0].$id[1].$id[2].
The issue type is: Backdoor:PHP/StringsConcat.13658
Description: Obfuscated concatenated strings
