I’ve been trying to create a new template and currently working on the workflow designer. However, after testing, it won’t proceed to the next workflow tab which is the “Human Resource”. There are also 3 non-workflow tabs in between Human Resource and End User. Why is this so that it won’t proceed? I’ve been working on the dependencies as well.
How can I move the 3 non-workflow tabs on the last part?
Hope you can help me. Thanks
