In a Template, move created workflow tabs right behind existing non-workflow tabs?
  • 14 July 2022
  • 169 views
I’m trying to edit a Request Template, and when you create a new request subtype and view the template it creates, the tab order is
Request Details; Approve (Workflow tab); Close; History; Related Items
But if I want a different workflow tab to replace Approve, is there a way to do that?
When I add one, it just gets added to the end of the list. I recognize if I want to rearrange workflow tabs with other workflow tabs,  I can do that, but that isn’t what I’m trying to do.
Thanks!
Best answer by mhaag 29 July 2022, 12:35
Hi @kyle.bgcdsb!
Will break down the answer to 2:
1 - Changing view of tabs in request template id defined on the subtype itself.
Check this out:
How to reach you Sub Types
Once in a specific Sub Type click “Design From” and choose the tab you want to customize and don’t forget to hit save!
Sub Type Design Form
2 - Changing the order of workflow and especially step “Approve” - can easily be done by drag n drop on our Workflow Designer check IT out
Same question here: I create a new Workflow tab, it gets positioned at the end of the list. I want “IT To Do” to be after “Approve”:
Drag and Drop in the Workflow Designer does not work, because there are no “non-workflow”-tabs.
Exactly, this is what I’m looking for, and currently it seems impossible.
There is a way to achieve this. What I’m doing is, I delete the non-workflow tabs then I add my workflow tab where I want it and after that I recreate all tabs that I deleted.
It’s clunky but it works.
