Could someone provide the syntax for adding notes field in custom notifications? I have it set to send information for the solution but I need the notes to get added to the notifications as well
Best answer by efranco_bis
View originalCould someone provide the syntax for adding notes field in custom notifications? I have it set to send information for the solution but I need the notes to get added to the notifications as well
View original$Notes |
You can see this page for all available options you can add to a notification.
Hello
So I tried that and performed so tests.. The notes doesn’t populate on status updates..
Hi
Best to reach out to our support team this time to get a solution.
You can contact us here:
https://www.sysaid.com/support
All the best!
