Editing custom notification to include notes fields
  • June 14, 2023
  • 147 views
Could someone provide the syntax for adding notes field in custom notifications? I have it set to send information for the solution but I need the notes to get added to the notifications as well
Best answer by efranco_bis
@Broderick to add notes to a notification the syntax is
$Notes
You can see this page for all available options you can add to a notification.
Edit/Create New Notification (sysaid.com)
  • June 14, 2023
$Notes
  • June 14, 2023
Hello
So I tried that and performed so tests.. The notes doesn’t populate on status updates..
Forum|alt.badge.img+2
  • June 28, 2023
Hi @Broderick
Best to reach out to our support team this time to get a solution.
You can contact us here:
https://www.sysaid.com/support
All the best!
