Good afternoon,
I had chatted with someone from SysAid support and they had mentioned that they would update our account to be able to send us a copy of the database for our own use (since i wanted to create some reports that are not possible via the sysaid reporting module, but i can't seem to find where the database was supposed to go into.
Would anyone have a clue where i could find it?
Copy of dB
Page 1 / 1
ggomez
Good afternoon,
Hi ggomez,
You can find it here:
Settings > customized event logs
in search box type "backup" and you will find the daily backups if enabled.
Let us know how it goes,
Maayan Karstaedtggomez
Good afternoon,
Hi ggomez,
My apologies for the late reply, but thank you very much!! I greatly appreciate the assistance.
