Does the Sysaid Svc account need Domain Admin rights if we are not installing the client?  We stopped using the client and cant see any reason not to remove these privileges.  Is there something I dont know about?
Thank you
G
if you aren’t using the client anymore I would think that you could move the rights to the box sysaid server run on and make it a local admin
Thank you for your reply!  I needed a little sanity check before we made the change.
good luck :)
let us know how if it worked, @gauer 🙂
We made the change yesterday at noon, and sofar no issues!
great, thank you!
I’ll mark your question as resolved
