Does Sysaid Svc acct need Domain Admin
  • June 16, 2023
  • 6 replies
  • 124 views
gauer
Community Enthusiast
Forum|alt.badge.img+2
Does the Sysaid Svc account need Domain Admin rights if we are not installing the client?  We stopped using the client and cant see any reason not to remove these privileges.  Is there something I dont know about?
Thank you
G
Best answer by jsidoti
if you aren’t using the client anymore I would think that you could move the rights to the box sysaid server run on and make it a local admin
jsidoti
Guru
  • Guru
  • June 16, 2023
gauer
  • June 19, 2023
Thank you for your reply!  I needed a little sanity check before we made the change.
jsidoti
Guru
  • Guru
  • June 20, 2023
good luck :)
  • June 20, 2023
let us know how if it worked, @gauer 🙂
gauer
  • June 20, 2023
We made the change yesterday at noon, and sofar no issues!
  • June 20, 2023
great, thank you!
I’ll mark your question as resolved
