Enable and disable a custom field within an AI
  • March 26, 2025
  • 23 views
Our install is on prem and we use the Admin Portal for completing workflow action items. Is there a way to either enable a custom field based upon a list selection or make that custom field required, again based upon a list selection?
Many thanks.
Hi ​@MrBeaker 😊,
Thank you for contacting us!
Could you kindly provide us with more details on what you would like to achieve? A use case or a specific example would be helpful in ensuring we fully understand your requirements.
Looking forward to your response.
