Example of Triggers with Field Customization
  • June 1, 2023
  • 52 views
We would like to add Java code to enhance some custom fields.  Is there an example of Triggers? Or currently the advanced tab for our fields goes to some code snippets for Form Display, Client-side validation, etc.  Should we use those fields?
Best answer by SysAid Team
Hi @mjbeebe
Please check out this document that will give you all the information you need regarding triggers: https://documentation.sysaid.com/docs/triggers?highlight=triggers
If you still need assistance, don’t hesitate to reach out :)
Forum|alt.badge.img+2
  • 52 replies
  • June 7, 2023
Hi @mjbeebe
Want Some cookies?
Cookie settings
