Help for create forms
  • 21 July 2023
  • 38 views
Hey guys, good morning!
I need help creating an IT ticket opening form. My idea is to create an opening form for the help desk and print a different form the guys for the field
My biggest problem is creating a data bond, for example, people put the address and the printing pulls that information.
Could clarify which best practine for create?
Best answer by PauloSantos 24 July 2023, 13:11
I found a solution for problem.
The path in sysAid for solution it is : Setting/Customization /List, in the list select the option a want for alteration value.
Grateful,
Hey @PauloSantos I’m happy you found the answer! and big thanks for sharing it here for the record! 🤗
