Incident Response Not Updating Incidents
  • September 5, 2022
  • 100 views
If a user responds to an email that is sent to them through SysAid the update does not appear on the Incident.  Is there a way to do this.  I have checked the email integration settings and it appears to be ok
Super SysMate
Forum|alt.badge.img+3
  • Super SysMate
  • September 6, 2022
Hi Shaun Davies,
does the response not appear in the Message field, or does the status not change as intended, or does the admin or admin group not get a notification?
If you could describe something more precisely, we could help you to find a solution.
  • September 8, 2022
Hello Karlson
The response does not appear in the message field at all, the status does not change.  Admins do net notified.
Shaun
Super SysMate
  • Super SysMate
  • September 8, 2022
Hi Shaun Davis,
can you check the following settings?
Super SysMate
  • Super SysMate
  • September 8, 2022
and here
