notifcation exception
  • October 3, 2023
  • 124 views
jsidoti
Guru
Afternoon Folks,
I’m trying to set up a flow from Salesforce Cases to Sysaid.
When a Salesforce case is assigned to a specific group I have it set to send an email to helpdesk@mycompany.org that will come from noreply@salesforce.org
Is there a way to tell sysaid to not attempt to send notifications to on ticket creation/modification/closure?
Best answer by Ioana Gotca
Hi John,
If you have a specific request user and you don`t want him to receive automatic email notifications, you can disable automatic notification at all from his account. In order to do this you need to go to Tools- End users- open his account and you should have the next option:
If you don`t have this option you can add it using Design form option.
Note this option will disable all automatic notification, not only the assigned admin notification.
Have a nice day!
Ioana
  • October 3, 2023
If you are receiving an email notification every time when a new incident is assigned to a specific admin group you will need to uncheck the next options:
 So, you will need to go to Settings- Service Desk- General- Assigned admin group click on + and uncheck all the options from the screenshot.
Have a nice day!
jsidoti
Guru
  • Guru
  • October 3, 2023
Ioana,
you may have misunderstood what I am asking about.
in this case, there is a specific request user I do not want to send notifications to
  • October 3, 2023
Hi John,
Have a nice day!
Ioana
jsidoti
Guru
  • Guru
  • October 3, 2023
thanks Ioana
