Power BI Extract Customise Output
  • May 3, 2023
  • 129 views
zoewalters
It is possible to customise the Power BI extract?
I have a monthly report that exports to CSV and arrives by email
When I attempt to set up the Power BI extract, these are the headings I have, and they are limited.
How can I match the email report items to the Power BI extract?
but my report headings are these and do not match the options in BI Analytics settings:
Best answer by Anonymous
hey @zoewalters
This integration is out of the box, so adding or removing fields is Feature Request. We have FR # 17827 that covers your case.
  • July 5, 2023
hey @zoewalters
