Pre-populated template fields not retaining values
  • August 20, 2025
  • 22 views
A majority of our support tickets are created by users sending emails to the helpdesk. For some common requests, we've set up email templates with pre-populated fields to streamline the process, minimise admin input, etc.
For example, a template for new user accounts includes a field for the account type (e.g., Domain, Google). This field is set to a default value, which is the most commonly requested account type. However, we've noticed that these pre-populated fields are no longer retaining their values when the template is used to create a new service request. This means the default value disappears and the field is left blank.
This issue occurs on templates created in Classic UI and on templates created in Spaces.
Info:
- SysAid Cloud
- SysAid Edition / Package: SysAid ITSM
- Build Number: v25.3.30 b4284
- SysAid ITSM Version 25.33.1.62702
Anyone else experiencing the same issue?
## Pre-populated template fields not retaining values
Thanks for the detailed info. This is a known behavior we’ve seen recently where default values on template fields (Classic and Spaces) don’t persist when records are created via email-to-ticket.
Quick checks and workarounds you can try now:
- Verify the default is set on the Sub-type form: Settings > Service Desk Templates > Sub-types > Edit Sub Type View > Design Form. Ensure the field is in Visible fields and has a Default value.
- If using Category-driven templates, confirm the correct sub-type/template is applied for the category that your email rules assign.
- Test creation from:
1) Admin portal “New” ticket,
2) Self Service Portal form,
3) Email (your usual flow).
Note where it fails—if only via email, it’s likely the current issue.
- Clear cache / hard refresh and re-test in Spaces and Classic to rule out UI cache.
Known patterns:
- Defaults and some custom fields lose values specifically on email-generated SRs.
- Affects both Classic-created and Spaces-created templates.
Recommended temporary workarounds:
- Use an Automation rule (Workflow/Rules) to set the field if it’s empty on creation (trigger: on SR creation; condition: field is empty; action: set to desired default).
- If possible, route those requests through SSP forms where defaults tend to stick more reliably.
If you can share:
- One affected template name and sub-type
- Field name (e.g., “Account Type”) and type (list/text/yes-no)
- An example SR ID created from email showing the blank field
- The category and email rule used
I can suggest an exact automation rule to enforce the default. If the issue persists after the above, please open a Service Record so Support can review your environment details and link it to the ongoing investigation.
