SLA Timer Reset
  • October 25, 2023
  • 158 views
Hi everyone,
I am currently working on creating SLA’s that are valid per area of our department.
The biggest issue is regarding escalations, and when waiting for a user to respond to a question.
My question(s): Can you reset an SLA timer when you set a status to: Awaiting User Response, or something very similar? When escalating a ticket, can you also change the timer when it is escalated?
Thank you,
Best answer by dragos.baciu
Hi everyone,
Thank you,
Hi @jherron,
Unfortunately, it is not possible to reset the SLA timer when you set a status to 'Awaiting User Response'. The SLA timer in SysAid is designed to run continuously once a service request is created and cannot be reset based on status changes. However, you can create a new status that stops the SLA timer. To do this, follow these steps:
1. Go to Settings > Customize > Lists.
2. From the List drop-down menu, select 'status'.
3. Create the new status that you want.
By creating a new status, you can set it as 'Pending' and configure it to stop the SLA. This will allow you to use the desired status when the SLA is stopped.
Have a lovely day ahead!
dragos.baciu
  • October 25, 2023
Hi everyone,
Thank you,
Hi @jherron,
  • October 26, 2023
Thank you @dragos.baciu! I will try this out and see how it goes.
