CentOS agent install updated
  • March 29, 2023
  • 66 views
jsidoti
Guru
Afternoon Folks
Putting this here in case it can help someone else and so I don’t forget
I installed the latest rpm from on=prem build v22.4.45 b2
  1. wget https://your-install-url/download/SysAidAgent.rpm
  2. sudo yum localinstall SysAidAgent.rpm
  3. sudo ./usr/bin/SysAid/SetupAgentSettings.out
    note: if your SetupAgentSettings.out isn’t there run find / -name SetupAgentSettings.out and substitute the path
  4. This will run and ask for your server url.. make sure to use http: or https: depending on your setup then Account name and then Serial number
  5. Answer any additional dialogs to match your particular setup
Then wait for it to report in
Good luck
  • April 13, 2023
Thanks for posting :)
