We have an asset group that is used to identify laptops that we loan to end users.  I would like to pull the asset group name into the CI record so that we can easily filter based on that group name.  I cannot find a way to import that field since it says that it is a Medium Text field and there is an error if I try to pull it into a Short Text field.  Any suggestions for pulling that field?
Thank you.
            Page 1 / 1
            Hi Crissmiller,
Can you share more details on what you are trying to achieve?
What field are you trying to map against and are you trying the operation from settings > CMBD > ?
If you can provide screenshots even better :)
Let us know,
Thanks!
                            Crissmiller
We have an asset group that is used to identify laptops that we loan to end users. I would like to pull the asset group name into the CI record so that we can easily filter based on that group name. I cannot find a way to import that field since it says that it is a Medium Text field and there is an error if I try to pull it into a Short Text field. Any suggestions for pulling that field? Thank you.
