Inventory update issues
  • June 21, 2018
  • 252 views
We continue to have issues with some pc's not updating. When we click update now nothing happens on some of our PC's. The only solution we have been given is to undeploy the agent and redeploy it. That option is taking too long. I'm attaching a few logs from 2 different PC's. Each one is getting a different error. 1 is getting this error: ttpGetReqHandler::SendGetMessagesRequest Failed to send http get request: URL = https://cent******** The other is getting this: Operating system error code: 10061, Description No connection could be made because the target machine actively refused it Exception description: Unable to connect to the remote server Inner Exception description: No connection could be made because the target machine actively refused it. If I undeploy and redeploy the updates start happening again but it seems like they just stop working again after a while.
  • February 24, 2019
Hello All, I have the same problem. I am using SysAid Cloud version. All computer are Win10 v.1803 The agent log file show: 02/21/19 20:04:48:282 [E] HttpGetReqHandler::SendGetMessagesRequest Failed to send http get request: URL = https://xxxx.ourit.support//agentmsg?accountID=xxxx&computerID=DELL-J6XFQ72®ister=DELL-J6XFQ72&RdsName=SysAid%20Server 02/21/19 20:05:18:532 [E] HttpGetAndPostMethods::GetRequest Error Description Failed to post data to the server https://xxxx.ourit.support//agentmsg?accountID=xxxx&computerID=DELL-J6XFQ72®ister=DELL-J6XFQ72&RdsName=SysAid%20Server <html><body><h1>503 Service Unavailable</h1> No server is available to handle this request. </body></html> Exception description: Error en el servidor remoto: (503) Servidor no disponible. en System.Net.HttpWebRequest.GetResponse() en SysAid.SAInfrastructure.Communication.HttpGetAndPostMethods.GetRequest(String pCurServerUrl, NetworkParameters a_pNetworkParameters, String& pResponse) Stack Trace HttpGetReqHandler::Run ExecutionContext::RunInternal ExecutionContext::Run ExecutionContext::Run ThreadHelper::ThreadStart Any help?
  • September 6, 2020
Dear all, I'm experiencing the same issue, currently running v17.4.21 b4. Note: I have see that internally there appear to be an error on the server reference of the sysaid configuration: https://trialmaster.sysaidit.com Regards,
