I am looking to leverage my On-Prem installation with a way to dedicate certain assets as “loaner” and then use Sysaid for requesters to check them out and back in.
Is there any way to accomplish this?
Best answer by Anonymous
Thank you for the explanation! We recommend using CMDB module in this case. You can import assets and create them as CIs (configuration items).
This knowledge base article might be helpful: How to create a template https://documentation.sysaid.com/docs/ci-templates
If you already have assets deployed with agents, you can use Import all assets to the CMDB and manage them there.
You can use the owner field and track who’s borrowing it. If you also want to track them by the barcode, you can use barcode scanner and associate them with CI via mobile app.
