Issue regarding upgrade of agent version
  • September 25, 2024
  • 89 views
Hi everyone
I’m facing an issue about job of upgrade agent version. Like attached, I have a lot of version of agent and I’m not able to upgrade them.
I’ve done a automatic job for to do this and does not working.
My current sysaid version is v24.3.30 b38 (Cloud) and I haven’t a Local RDS.
Somebody has any way to solve this?
Best answer by abonfim
Hi there.
Just to close this loop. The version of my sysaid was upgraded and now the upgrade about agent is working fine.
My version now is 24.3.60.171
iulian.olaru
Check if the assets are successfully communicating and if the RDS is operational. You may need to simply undeploy the agent on these assets an then redeploy it.
Here is a guide: https://documentation.sysaid.com/docs/agent-deployment-plan-form
  • September 26, 2024
Hi There
In my case, is not simply undeploy and redeploy because I only have the RDS from cloud by Sysaid.
is there another way so solve this?
  • September 30, 2024
Hi there.
