Hi Guys,
I’m facing here the issue about how to the “Enable” automatically the label “Pacth Management”
Anyone has this solution?
For Exemple: The new assets join the Sysaid plataform and automatically the pacth management is enable
Another issue that I have is that I have a lot of asset into the plataform with patch management disable. How could I set to enable in massive way?
Hi ​@abonfim,
Unfortunately, there currently is no option to have Patch Management be enabled by default on new assets.
We do however have a feature request open for adding this option, ID 2284. If you wish, I can raise a ticket in your name and link it to the feature request so that you can get automatically notified via email when it is implemented. For this I would require your email address, if you would be so kind as to provide it to me either here or in a private message.
To enabled Patch Management in bulk for assets go to Assets > Asset List > select the assets using the checkboxes on the left > click on the 3 dots next to the ‘Set’ button > More Actions > select Patch Management and Enabled from the dropdowns > Save > Set
Hi adrian,
Thanks a lot!!
Yes, you can put my e-mail on this ID. I’ll send to you on private.
Talking about the instructions about how to do in massive way, Thanks. I’ll do that!
