SNMP command line tools - SNMPWALK, SNMPGET - Examples
  • June 17, 2009
  • 12 replies
  • 13272 views
Oded  M
Dear SysAid Lab members ! For those of you who want to make the most out of the SNMP network scanning - I would like to forward all of your attention to an open source command line tool for snmp queries you can use to learn a lot about your devices and then configure SysAid to extract and save that information. This net-snmp tool will allow you to be able to send simple queries to your SNMP devices and receive the values. You can also run a full SNMP walk command and get all the values from the device. We developed a small SNMP tool based on the command line tool with a user interface you can simply [url=http://cdn3.sysaid.com/VisualSNMPSetup.exe]download and run the Windows version. ([url=http://cdn3.sysaid.com/VisualSNMP-linux-x64.tar.gz]Linux and Mac versions are also available) Learn more about the tool Here If you wish to go for the command line tool follow the instructions below: Download the third link on the download page or click this direct link : net-snmp-5.4.2.1-1.win32.exe Perform a default installation – next next…. Open a command line prompt in Windows: (cmd) The following command lines are usefull: Get value of a single OID: snmpget -v1 -c public <device IP> OID Example : snmpget -v1 -c public 192.168.1.1 1.3.6.1.2.1.43.5.1.1.1.1.0 Get all values of a sub tree: snmpwalk -v 1 -c public <IP-ADDRESS> mib-2 snmpwalk -v 1 -c public <IP-ADDRESS> private snmpwalk -v 1 -c public <IP-ADDRESS> mgmt The outputs are long so you can add "> file1.txt" to the end of each command : snmpwalk -v 1 -c public <IP-ADDRESS> mgmt > mgmt.txt If you find OID-s of interesting information for printers like page counter , toner level , or any other interesting information for network devices – please post them here ! Good Luck ! Oded
Guillaume
  • June 17, 2009
Hey ! Nice to know !! Thanks! Good Call !
TRS-80
  • September 28, 2009
Thank you for this tool. Previously, I had to log on to a linux box to get this functionality. Now I can do this from my pc. :)
Lev
  • June 22, 2010
Here are some OID's i have found: 1.3.6.1.2.1.43.10.2.1.4.1.1 HP Printer Total Page Count 1.3.6.1.2.1.47.1.1.1.1.11.1 ProCurve Serial 1.3.6.1.2.1.43.5.1.1.17.1 HP Printer Serial If some body will give an idea for OID's I'll try to find them. Those 2 free tools can help you as well. HiliSoft - MIB browser Script Logic - sl360 tool suit (there are nice free tools not only for SNMP) Lev
  • February 28, 2012
hi, I installed succefully the net-snmp.exe but when I tried to tape some comands in the cmd like snmpget or snmpwalk I get a message like that: 'snmpget' is not recognized as internal command or external, operable program or batch file. plz can anyone help me and thanks 🙄
  • August 30, 2012
kamika
position you cursor to the folder that you install SNMP.
  • August 30, 2012
I found OID for RICOH counter: C:\snmp\bin>snmpget -v1 -c public 192.168.1.81 .1.3.6.1.2.1.43.10.2.1.4.1.1 SNMPv2-SMI::mib-2.43.10.2.1.4.1.1 = Counter32: 45069 I used: C:\snmp\bin>snmpwalk -v 2c -c public 192.168.1.80 >80.txt after that open 80.txt and compare counter from machine and txt file ;-) note* in snmpwalk I use ver 2 of snmp protocol.
Provided is a whitepaper I wrote a while back on Net-SNMP and using SNMP at the Command Line - CLI I also have a section in here about using NET-SNMP in scripts https://www.tobiassystems.com/?page_id=944 Hopefully this helps everyone
  • June 21, 2015
Is this thread still alive? I have a few questions on information i am trying to gather. Thanks, Matt
Danny Tashiev
Hi Matt, You're welcome to ask questions, we're listening :) Cheers, Danny
Oded  M
  • January 16, 2017
You can watch an snmp scan in action from within SysAid network discovery https://www.youtube.com/watch?v=1Ab2lh9QHVw
Oded  M
  • January 25, 2017
You can Watch a short video of the SNMP tool in action.
  • September 25, 2017
Would it be possible to add MIB file importing to the tool? I think that would be very helpful with interpreting the information that comes back.
