Additional contact
  • September 2, 2022
  • 58 views
Is there a way to add aditional contact to your ticket so if there is any update the user and the manager get’s update automatically?
Super SysMate
Forum|alt.badge.img+3
  • Super SysMate
  • September 6, 2022
Yes, there is a CC field that you can integrate into your template!
cheers Karlson
  • September 7, 2022
yes but you need to add them to the email what you sending however ther is an email coming in from a third party the aditional contact is not get notifield, also I would need blind cc as well.
Super SysMate
  • Super SysMate
  • September 7, 2022
Hi DGAl,
I think I understand!
For example, if we contact a supplier via email from a ticket, we use the "Addendum User" field!
All messages flow into the ticket, but the end user will not be able to see the messages, not even via the SSP.
cheers
Hi @DGAl , can you elaborate more on the scenario so we can find you the best fit?
is this ticket part of a workflow? a regular incident? what are the steps you are expecting?
in the meantime you can rsee where to configure CC filed here:
