Custom Notifications - where field "contains" or is "like"
  • August 30, 2022
  • 141 views
I’ve found the article on how to put some nifty customisations on the Sysaid notifications, and it allows us to do a “not” and “equals” check - e.g.:
#if( ${Status}==”In Progress” )
#if( ${Solution}!="" )
However, I was wondering - does the system support “contains” or “like” operators?
I was hoping to do something along the lines of:
#if( ${Description} like "*forgot my password*" && ${Description} like "*SystemX*" )
    <p>Did you Know? You can hit the ‘forgot my password’ link in SystemX to reset it? View the How-To article here: <a>link</a></p>
#end
Best answer by james.reynolds
Thank you.
This is an example of what worked:
    #if($Description.indexOf("telephone") > 0)
        contains telephone
    #end
Here’s an alternative method which might be useful
    #set($myString = ${Description})
    #if($myString.indexOf("telephone") > 0)
        contains telephone
    #end
Hi @james.reynolds
The notifications are written in Apache Velocity language check the supported operators here:
https://velocity.apache.org/engine/1.7/user-guide.html#relational-and-logical-operators
  • September 19, 2022
Thank you.
        contains telephone
    #end
        contains telephone
    #end
Thanks @james.reynolds for sharing the love!!
