Edit template
  • March 10, 2025
  • 38 views
How do I add a place for users to add in the room number, in the user information when they create a incident?  I want to edit the template so they can put in the room number they are in that they are requesting help.
  • March 13, 2025
Hello ​@sharimorse, thank you for reaching out.
Our support team will reply here shortly.
Best,
Ella
simonamirza
  • March 18, 2025
Hi ​@sharimorse,
Here’s how you can create a custom "Room Number" field and add it to the Request/Incident Submission Forms in the Self-Service Portal (SSP):
Step 1: Create the Custom Field
  1. Navigate to Settings:
    • Go to Settings > Customize > Field customization.
  2. Add a New Field:
    • Select the relevant entity(Service Record).
    • Click on New to Add Field.
  3. Configure the Field:
    • Set the Field Name to "Room Number".
    • Choose the appropriate Field Type (e.g., Text, Number, etc.).
    • Save the field.
Step 2: Add the Field to the Form
  1. Open Form Designer:
    • Go to Settings > Self-Service Portal
  2. Edit the Form:
    • Select the Request or Incident Submission Form > Designer Form.
  3. Add the Custom Field:
    • In the Available fields column, look for the "Room Number" field and move it into the Visible fields column.
  4. Save Changes.
Step 3: Test the Form
If you use Spaces, please refer to the below steps:
    • Go to Settings > Customize > Fields.
  2. Add a New Field:
    • Select the relevant module (e.g., Requests or Incidents).
    • Click Add Field.
    • Choose the Field Type (e.g., Text, Number, etc.).
    • Save the field.
  1. Go to Form Designer:
    • Navigate to Settings > Self-Service Portal > Form Designer.
  2. Edit the Form:
    • Select the form you want to modify (Request or Incident submission form).
    • Drag and drop the "Room Number" field into the desired section of the form.
  4. Save Changes:
    • Save the form to apply the changes.
  • Open the SSP and submit a test request/incident.
  • Verify that the "Room Number" field appears and functions correctly.
