Multiple escalation rules per template
  • August 25, 2023
  • 64 views
I’ve setup a problem template and a couple of unique ticket statuses restricted to this template and trying to apply multiple escalation rules to this particular template, There are 4 rules in total.
For testing purposes I’ve set each rule to be 5 minutes apart:
Rule 1
Escalates service records with type Problem, only non-merged tickets, with category Bug, with sub-category General, with status Sent to team X. Triggers on 0 hours 10 minutes after ModifyTime. Notifies: ME!, Administrator.
Escalation Level 1
Rule 2
Escalates service records with type Problem, only non-merged tickets, with category Bug, with sub-category General, with status Sent to team X. Triggers on 0 hours 15 minutes after ModifyTime. Notifies: ME!, Administrator.
Escalation Level 2
Rule 3
Escalates service records with type Problem, only non-merged tickets, with category Bug, with sub-category General, with status Sent to team X. Triggers on 0 hours 20 minutes after ModifyTime. Notifies: ME!, Administrator.
Escalation Level 3
Rule 4
Escalates service records with type Problem, only non-merged tickets, with category Bug, with sub-category General, with status Sent to team X. Triggers on 0 hours 25 minutes after ModifyTime. Notifies: ME!, Administrator. Set the following fields: Admin group = Service Desk
Escalation Level 4
From testing I’m finding that its taking approx. 30 minutes to send the notification for Rule 2 - Instead of 5 minutes? Am I overlooking something?
Best answer by iulian.olaru
From our documentation:
“After having determined which service records to escalate, you must then determine when they will escalate.
Escalation rules are triggered within a five minute (On-Premises) or ten minute (Cloud) window of the time you specify here.”
Read more:
https://documentation.sysaid.com/v1/docs/new-escalation-rule.
iulian.olaru
  • August 25, 2023
Read more:
