New feature request , changing the execution order of routing rules
  • November 6, 2023
  • 68 views
Hi team,
It would be great if there was an option to change execution order in the routing category.
For eg: if there any many routing rules and we want to add a rule that should be implemented or should appear in the the second position of the routing rule. Currently i think that is not possible.
It would be great if there is like a drag the a particular rule and place it at any position we want.
  • November 6, 2023
Thank you for your feedback ! Please connect to a channel and raise a ticket via chat/email with support in which you provide a detailed use-case for this feature so that maybe they are able to raise a Feature Request for this.
Thank you !
