API - Python
  • 18 April 2023
  • 193 views
Hi All,
Has anyone successfully created a Python script to query the Sysaid API? I’ve been struggling to get this working … POSTMAN is working fine though.
Just wondered if anyone had a sample script i could look at.
Thanks,
Best answer by cary512 31 May 2023, 23:39
Hi @infoMarlee
In general, creating Python scripts for API calls is not in our scope of support.
However, if you give us an example of what you’re trying to achieve, we’ll try to ask around internally and see if there’s anything we can help you with.
All the best :)
I just posted some python code a few hours ago regarding a problem with attachments.  That could get you started.  I didn’t include a login routine so you’re going to get a 401 response every time, until you handle that.  You could merge that code with the code below and should be able to get it working.  I extracted this from a larger codebase so there’s probably some bugs.  At the very least I think I used “/tmp” for the cookie path in that other code instead of the account-specific path found here.  Good luck!
import urllib
username = "my-sysaid-username"
rawpass = "my-plaintext-sysaid-password"
def login():
    global headers
    headers = { 'Content-Type': 'application/json' }
    logininfo = {'user_name': username, 'password': urllib.parse.quote_plus(rawpass)}
    saurl = "https://%s.sysaidit.com/api/v1/login" %account
    response = session.post(url=saurl, headers=headers, json=logininfo)
    if response['status_code'] == 200:
        # login successful - store the session id
        scresponse = save_cookie(response['headers'])
        return scresponse
    return False # login failed
def save_cookie(rheaders):
    global headers
    cookiestr = str(rheaders['set-cookie'])
    cookie = cookiestr.split(';')[0]
    headers = { 'Cookie': cookie, 'Content-Type': 'application/json' }
    os.makedirs("/tmp/sysaid/%s/state" %account, exist_ok=True)
    with open('/tmp/sysaid/%s/state/jsessionid' %account, 'w') as fd:
        fd.write(cookie)
        fd.write('\n')
        fd.close()
        return True
    return False
Userlevel 3
Hi @infoMarlee
Please let us know whether @cary512’s response helped you out and if it resolved your issue.
All the best :)
