Automate Basic Request to Advanced
  • April 21, 2020
  • 36 views
Hello, When a user submits a request using the self-service portal, it defaults it to a basic request process. I then change the template on my side to follow an advance format. In a perfect world, the basic request being submitted with Category = A and sub-category = B would change it to the advance template I would like. Is that not a possibility? Thank you!!
  • October 13, 2020
Hey Kat, yeah, you can automatically update the template based off the selected categories. You have to change that in the settings for the category. There's a dropdown field with the default value "don't change", it should list all your templates.
