How to increase 40 character length
  • May 21, 2024
  • 128 views
I have an issue where I am trying to upload an address that is 40 characters. SysAid importing tool will not upload the record to the database. Is there a way of increasing the limit?
Hardeep
To address the issue of uploading an address that exceeds the 40-character limit in SysAid, you can create a new custom field with a higher character limit. Here are the steps to create a new 'Text Area' field, which supports up to 65,000 characters, ensuring that your address can be uploaded without any issues:
1. **Navigate to Field Customization**:
- Go to `Settings` > `Customize` > `Fields Customization` > `Service Desk`.
2. **Create a New Custom Field**:
- Click on the option to create a new custom field.
3. **Select 'Text Area' as the Field Type**:
- Choose 'Text Area' as the field type. This type of field supports a significantly higher character limit compared to the standard 'Text' field.
4. **Configure the New Field**:
- Set the caption and any other required settings for the new field according to your needs.
5. **Save the Changes**:
- Save the new custom field and use it for uploading addresses that exceed the 40-character limit.
By following these steps, you can ensure that your address data is successfully uploaded to the SysAid database without encountering character limit issues.
dragos.baciu
Hi @deepslalli
Depending on what is tried to be imported different areas work different.
If this is related to a field character limit you can create a new custom field with a higher character limit. Here are the steps to create a new 'Text Area' field, which supports up to 65,000 characters. You can do this by going to Settings > Customize > Fields Customization > Service Desk > New > Choose 'Text Area' as the field type > Set the caption and any other required settings for the new field according to your needs > Save.
If you need more help, have further questions, or just want to chat about this topic, please don't hesitate to reach out to us via email or contact us via chat.
  • May 21, 2024
Thank you so much for the response, I just have a follow up question, I believe I should try to keep
“DB Field Name” and as I can’t edit the field in question. So can I delete what I already have, then do step 3 and then use the same DB Field Name for that new entry?
TIA
