Initial RDS Setup
  • September 2, 2024
  • 181 views
Hi all,
we are just getting started with Sysaid implementation and it has been a bumpy road, nevertheless I have installed RDS on one of our servers, followed the documentation, however in sysaid portal, I only see one RDS node which is sysaid server. i am not sure if that is how it should be or not, but i have no option to add new one.
if I go to do any sort of WMI or SNMP scan, I also cannot choose RDS nor Domain, which makes me think there might be a step that i have missed after installing the RDS.
PS: I have assigned credentials to RDS , I have no way of confirming whether it is working or not.
I would appreciate any help on this one.
Best answer by simonamirza
Hi @CycloAdmin,
We have submitted SR #2510879 to further investigate this incident.
I will follow up with you shortly via email to resume troubleshooting.
**AI magic at your service!**
To address the issue of your RDS not appearing in the SysAid portal and being unable to perform WMI or SNMP scans, please follow these steps:
### Preliminary Checks
1. **Verify RDS Installation:** Ensure that the RDS installation was completed successfully. You can check the installation logs for any errors that may have occurred during the process.
2. **Check RDS Service Status:**
- Navigate to the machine where the RDS is installed.
- Open the 'Services' console by typing 'services.msc' into the Run dialog (Windows Key + R).
- In the Services list, locate 'SysAid Discovery Service'.
- Check if the service is running. If it is not, right-click on it and select 'Start'. If it is running, try restarting it by selecting 'Restart'.
3. **Verify Network Connectivity:** Ensure that there are no network issues or firewall restrictions blocking communication between the RDS server and SysAid.
### RDS Configuration Verification
1. **SysAid ID and URL:** Double-check that the SysAid ID and URL entered during installation are correct and match your SysAid account details.
2. **Check RDS Node in SysAid:**
- Log in to your SysAid Administrator account.
- Navigate to 'Settings' from the main menu.
- Select 'Network Discovery' from the submenu.
- Click on the 'RDS' tab to view the list of RDS nodes.
- Ensure that the newly installed RDS node appears in the list.
### Advanced Troubleshooting
1. **Logs Analysis:** Check the RDS logs for any error messages or clues. The logs can typically be found in the `C:\Program Files\SysAid Remote Discovery\root\WEB-INF\logs` directory.
2. **Re-verify Installation:** Ensure that all components were correctly installed. Sometimes, reinstalling the RDS can resolve unseen issues.
### If the Issue Persists
If after following these steps the issue remains unresolved, it might be necessary to delve deeper into the configuration or potentially involve SysAid support for a more in-depth analysis.
1. **Contact Support:** Since a Service Record is already open for this request, please update it with the steps you've taken and any findings. Include detailed logs and error messages if available.
I hope these steps help you resolve the issue with your RDS setup. Please let me know if there's anything else I can assist you with.
simonamirza
  • September 2, 2024
Hi @CycloAdmin,
