Adding Default Text to SR
  • August 16, 2021
  • 92 views
jsidoti
Guru
Afternoon, I've been trying to customize out a new employee template. I'd like it to show some default text in text and text area fields. I thought it was in the Default value area when I added a field to a form, but it is not displaying Any leads are appreciated John
alefabian
  • August 25, 2021
Go to the list of your templates (under Settings > Service Desk Templates > [...] Templates) and open the specific template. You can simply input the default value on the text field and then save the template.
jsidoti
Guru
  • Guru
  • August 25, 2021
alefabian
that is exactly what I was looking for Thank you
