Consolidating Categories
  • September 10, 2025
  • 61 views
This is more of a general question, I have a number of existing SysAid categories that are similar/same. I’m looking to consolidate them.
There are a spread of archived/closed tickets in some of these categories.
I need to know if SysAid will send notifications out on CLOSED tickets that will need the category updating to either the initial submit user or the watchers on the service records?
Is there anything else I’d need to consider?
## Consolidating Categories – What to Expect and How to Do It Safely
Short answer: SysAid won’t automatically notify users when you change categories on closed tickets, but notifications can be triggered by escalation rules or bulk operations if they’re configured to send emails. Disable/suppress notifications before any mass change to be safe.
Key points and recommendations:
- Notifications
- Manual edits on closed SRs typically don’t send emails by default.
- If you use an escalation rule or automation to recategorize, it can send emails if its action or related notification rules are enabled.
- Before any bulk change:
- Temporarily disable relevant notifications (Settings > General > Notifications) or
- In the escalation rule, uncheck email actions and ensure no “on update” email is fired.
- Ways to consolidate
1) Rename the old category to the new name (Settings > Service Desk > Categories). This updates existing SRs’ displayed category label instantly.
2) One-time escalation rule: Filter SRs by old category and set Category to the new one. Run once, then disable/delete the rule. Keep emails off.
3) CSV export/import: Export SRs, change category values, then import using SR # as key to update only the category field. Disable emails during import.
- Impact on archived/closed tickets
- Renaming a category updates how it appears on those tickets.
- Deleting a category prompts you to transfer SRs to another category; otherwise, historical reporting/search can be affected.
- If you delete without mapping, some reports/filters can lose that category context.
- Additional considerations
- Test on a small set first (and during a maintenance window if possible).
- Back up a CSV export before mass changes.
- Temporarily disable outgoing mail system-wide if you’re unsure of rules.
- Review reports that rely on old categories; plan mappings for continuity.
- Document your old-to-new category mapping for audit and future reference.
If you want, tell me:
- Which old categories map to which new ones
- Whether you prefer rename vs. rule vs. CSV
- Whether notifications are currently enabled for “on update” or escalation actions
I can outline exact, click-by-click steps tailored to your setup.
Hi Justin,
Hope you are doing well.
As our copilot mentioned SysAid won’t automatically notify users when you change categories on closed/archived  tickets unless you have some escalation rules set-up for one of the statuses.
Please let us know if the information helped and if further assistance is needed , please also provide us with your email address.
Thank you for your time and have a nice day!
