Custom Fields in Emails
  • February 17, 2023
  • 179 views
When i use the following:
${sr.getAddonFieldValue("CustomColumn34sr")}
The output is 125.
125 is the ‘Reference id’ of my profile. If I put someone else's name in the field, it shows their ID. How can I change this to show their name instead if their reference id?
I have followed this:
“Hi Chris,
Please try this instead and let me know if this works:
$AccountObj.getCustValues("sr_cust_sbm_proj_code",$AccountObj.getResourceBundle()).getCaption($sr.getAddonFieldValue("CustomColumn5sr"))
Danny”
so in my case, it will be:
$AccountObj.getCustValues("sr_cust_test_listtt",$AccountObj.getResourceBundle()).getCaption($sr.getAddonFieldValue("CustomColumn34sr"))
the ‘125’ is from ${sr.getAddonFieldValue("CustomColumn34sr")}
We are on cloud hosting.
Hi @Leon Symnz !
Is your custom field is multi select or relational you need to use this tag:
${sr.getAddonFieldValueCaption(“CustomColumn34sr”)}
Hi @Leon Symnz !
  • February 22, 2023
Hi @Leon Symnz !
Morning,
I was emailing with Vlad yesterday and he provided me the same. This is working.
Thanks again
  • May 17, 2023
Hi @Leon Symnz !
I know it has been a while but I believe there’s an error in your answer. it should be ‘CustomColumn34sr’ not “CustomColumn34sr”
