Customizing Log Headings
  • December 6, 2021
  • 34 views
godef
Community Enthusiast
Can this be done for Request Logs? See attachment. A lot of the columns don't apply. For instance, there was already a Priority field with a list of options different than what I desired, so I create a "Request Priority" list. So I want to change the Log Headers to take out Priority and insert "Request Priority". -thanks
Hi godef! You can customize your view here: After clicking "Customize View" you can add and remove the fields you want to see and decide if you want to choose to update existing views or create a new one all together Let us know how it goes! Cheers, Maayan
godef
