Direct link to pre-filled SR template
  • August 4, 2015
  • 16 replies
  • 269 views
Howdy. This may be a feature request, but I'm hoping that there is a simple solution. I would like to be able to send customers a URL that will lead to a new service request form pre-filled with a service request template. If I send a link like this: https://my.sysaid.instance/SubmitSR.jsp?quick_name=33889 the correct template is selected in the SR submit form. BUT the other fields are not updated with the template settings. If I then switch the selected template to something else and switch it back to the one I want, then the fields will be pre-filled. Is there a way to send a direct link to a pre-filled template? Thanks, Jeremy.
Danny Tashiev
Hi Jeremy, You can use the following: https://my.sysaid.instance/SubmitSR.jsp?populateSR_id=33889&populateSR=true I understand you also have a ticket on this topic in our helpdesk. Is it ok to close it? Cheers, Danny
  • August 5, 2015
That works perfectly! Thanks so much! Yes, you can close the ticket.
DaveTrafford
  • May 12, 2017
Hi Danny, I am trying to do the same. Is the 33889 the template #? Thanks, David
DaveTrafford
  • May 12, 2017
By trial I found this does still work! The 33889 is the template number. I am stoked!
Woosty
  • February 8, 2018
Hi Guys Just to clarify, if I create a request, save it (so it has a ticket number) then use the link - https://my.sysaid.instance/SubmitSR.jsp?populateSR_id="TICKET NUMBER"&populateSR=true This will send my customers to a pre-filled template that they can add a little more detail to (location, time etc.) and then submit as a new ticket? Thanks in advance. Paul.
Danny Tashiev
Hi Paul, No, information from existing tickets will not be pulled. It will only be pulled from templates you have created and the user can use. The method for this is described in my previous post (populateSR_id). Cheers, Danny
Woosty
  • February 8, 2018
Thanks for the reply Danny I don't think I follow, sorry. How can I create the template in the first place please?
Danny Tashiev
Under Settings > Service Desk Templates > Incident/Request Templates > Add Incident Template. You can use the # of the created template for the link discussed in this thread.
Woosty
  • February 8, 2018
Sorry Danny, I'm being a bit dim... So I'm logged in to http://my-company/Home.jsp and click on my face in the top right corner and click on My Settings? I don't seem to have Service Desk Templates? I don't think I'm in the right place... :(
Danny Tashiev
You click on the cogwheel icon to access SysAid Settings.
Woosty
  • February 8, 2018
Hi Danny I only see the attached when I click on the cog...
Danny Tashiev
This means you are not a full SysAid Administrator. Please contact the person who has the permissions to access this area. Cheers, Danny
Woosty
  • February 8, 2018
OK, thanks for your help Danny. :)
  • January 30, 2020
This only seems to work with incident templates. I can't see to get it to work with request templates. Am i missing something?
alefabian
  • January 31, 2020
The link is still valid and works with Request templates as well: https://my.sysaid.instance/SubmitSR.jsp?populateSR_id=[ID_Template]&populateSR=true If you are using the Self-Service Portal, use: - for Incident: /submitIncident?populateSR_id=[ID_Template] - for Request: /submitSR?populateSR_id=[ID_Template] Online help: https://community.sysaid.com/Sysforums/helpData.page?helpId=14973
  • February 19, 2020
I'm still running in to a few issues as follows: I am using this URL: http://my.sysaid.instance/SubmitSR.jsp?&populateSR_id=[template]&populateSR=true and point it to a request template. But when a user access this, they get the correct template form, but my system submits as an incident, not a request, even though the template is a request template. So I enabled the self-service protal and used this url http://my.sysaid.instance/SubmitSR?populateSR_id=[ID_Template] but I get a 404 error, requested resource is not available. If I use SubmitSR.jsp, in the URL, users get to the form but it still submits as an incident. Notice I also had to capitalize the "s" in Submit. I reviewed the help article at https://community.sysaid.com/Sysforums/helpData.page?helpId=14973, but I don't see the Toolbox Widget Items in my instance. I am on v19.4.41 Pro Plus Edition.
