Edit Default Basic/Advanced Request Template
  • November 21, 2016
  • 6 replies
  • 169 views
Is it possible to edit the default basic/advanced request templates to remove the statement "If relevant, add this Request details to the Knowledge base. Close the Request." out of the notes of those templates?
Danny Tashiev
Hi David, It's possible. First you'll need to disable the "Allow notes to be added only by using the "Add a note" button" option under Settings > Customize > Apperance, then access the relevant template and simply delete the text (and press Apply). You can re-enable the former option afterwards. Cheers, Danny
  • November 22, 2016
Thanks Danny. That solved it.
  • April 22, 2020
That did not work for me.
  • July 21, 2020
Same here, I see no way to delete the text, as is stated.
  • July 30, 2021
I need to be able to do this too. Help!
  • November 19, 2024
I think things have changed since this was originally solved 7 years ago and there will need to be a new request.
